Tail Lights
Old Jul 23, 2011 | 08:58 PM
Norwichdelta06's Avatar
2007 c230
Tail Lights
Alright guys. My the 2007 C230. Are all the tailights the same across even the rear fog lamp? Because i'm looking at all the bulbs and they are double filament. And the reason why I ask is because my rear fog is no longer working and im swapping bulbs to figure out why? I cant seem to figure it out so im just going to replace all 4 and see what happens from there
Old Jul 23, 2011 | 09:54 PM
giannidy's Avatar
2001 C320
There is only one rear fog light
Old Jul 24, 2011 | 12:57 AM
2007 c230
yes but the tailights are all double filament bulbs when i looked at them. And the rear fog light bulb is a one of the 4 bulbs.
Old Jul 24, 2011 | 11:00 AM
OneOfaKindTrini's Avatar
Nike Turbo Shox
Theres a foglight for the rear on the drivers side i believe.
Old Aug 2, 2011 | 10:18 AM
drtyjrzy's Avatar
05 C230K Sport
I hope someone will correct me if I am wrong, I believe they are all double filament because the second filament lights up with brake lights. if you stand behind the car and count from left to right it should be bulb 2 that is the fog light (inside of driver side) and the second filament is lit when braking or if the rear fog switch is on.
Old Aug 2, 2011 | 11:31 AM
2007 c230
The only Brake lights are the spoiler and the two single filament bulbs ontop
Old Aug 2, 2011 | 03:50 PM
MW_ATL's Avatar
'02 C230 Coupe (Me) '03 SLK320 6MT (Wife)
In addition you will find a double filament bulb in the tail light on the right side, but it is not used for anything (for us).
The bulb carriers are identical from side to side, so the bulb that fits is the dual filament. I would assume that way they can use the same bulb carrier for LH or RH drive (their rear fog is on the opposite side, is it not?)
