Air only blowing on feet after re installing COMAND
Old Aug 4, 2011 | 04:03 PM
chmura's Avatar
2007 C230
Last night I had to take out my COMAND unit because it was not working, after reinstalling it my air only blows on the feet. What could have happened?
I can adjust the power settings from 1-6 that works, but changing the positions to where I want the air to blow does nothing. To take out the COMAND i had to take out the top middle fans out.
Old Aug 5, 2011 | 01:28 AM
c230yvr's Avatar
To take out the comand you should have removed the vents only (no mechanical parts in there) but you would have also had to remove the climatronic control panel. Its possible one of the connections came loose from the back of it when you moved it, I'd start there.
Old Aug 5, 2011 | 01:59 AM
samaritrey's Avatar
Super Moderator
THE C350
You did not plug back in the ribbon cable to the ac display It is a black flat cable
Old Aug 5, 2011 | 11:57 AM
chmura's Avatar
2007 C230
Thanks guys I'll check that out
Old Aug 5, 2011 | 06:09 PM
chmura's Avatar
2007 C230
That was the problem thanks again!
