upgrade to OEM navigation head unit.
Also, if you have the upgraded Bose audio system, you will have the get the COMAND unit re-coded to recognize the Bose amp, or if he has the Bose system, you need to get the COMAND unit re-coded to use your stock amp.
Also, his car needs to be a 2005-2007 model or else the COMAND unit is not compatible with your car.
You will also require a navigation DVD. If the disc is an older one (from 2005-2007) you may need a software upgrade to successfully load a current navigation DVD in the unit.
If you want to see navigation instructions in your instrument cluster, you will have to get your car re-coded at the dealer to enable that function.
