How to take of this panel?
Old Sep 23, 2011 | 07:13 PM
Ribo89's Avatar
a Tank
Hi,
I need to take off the panel on the drivers side where the seat belt comes in and out on my 01 c320. Here is the picture of what I need to fix. How do I take if off?
Thanks,
-riBO
Old Sep 23, 2011 | 07:24 PM
mercetek's Avatar
2011 C250 4-matic
Pull back the weather stripping around the area of that "b" pillar. Pry off the oval trim above the seat belt height adjuster. You probably don't need to remove the whole trim panel but simply pry it back once you remove the 3-4 steel spring clips underneath the weatherstripping/door seal. It's quite possible the adjusting trim came dislodged from the track only. Good luck.
Old Sep 23, 2011 | 07:46 PM
Ribo89's Avatar
a Tank
Thanks. I didn't know it was called "b pillar". I found a PDF on how to do it. http://www.benzworld.org/forums/atta...m-b-pillar.pdf
