hyper white bulbs and turn signal mirriors
03 c230
hyper white bulbs in the turn signal mirriors?
i was wondering if there is a aftermarket bulb that can replace the oem bulbs? im looking for a hyper white bulb ? could it be done?
The True OG Modded out W203
A MBWorlder named Viktorious posted instructions and what bulbs he used. Sorry you would have to STF...
Just so you don't get an unpleasant surprise, you should be aware that since the mirror turn signals can be seen from the rear of the car, white bulbs would be illegal. I doubt that you would be ticketed, but you never know.
W209 - W163
Since im such a nice guy, ill re-post the instructions...
What you need:
- 3 to 6 Packs of Sylvania Bulbs #2721 or #2723 (Got them from Pep Boys, 2723 is brighter)
- 2 Torx Screwdrivers # 9 and 10
- Flat Head Screwdriver
Step 1- Removing the Mirror Housing
There are four screws in total accessible from the mirror side. Use the controls to move the mirror away so it can be accessed easier. Use the #10 screwdriver to remove 3 screws, but use the #9 for the inside corner screw. Its hard to get the screwdriver in there, so a slightly smaller size head would work well.
After removing the screws, tug carefully until the outer lip of the mirror cover is out. Then, lift the outside housing UP then OUT... It won't come all the way off, but enough for you to work with the bulbs.
Step 2- Changing the Bulbs
To change the bulbs, just use a small, flat screwdriver to pop the lights up. Don't try pulling the wires as you might break them. Simply pull those orange lights out, and put the new ones in.
Now, you can change all 6 bulbs per housing, but I recommend not to. I suggest you just change the 3 on the outside. Doing so will automatically shutoff the 3 on the inside (different voltage). You can change all 6 per housing, and all 6 will light up, but it won't be as bright as if you only changed the outside 3. BUT, DO NOT REMOVE the 3 orange bulbs inside. Just leave them in place. Just change the outside 3 if you wish, or change all 6.
And thats it. Just go backwards to put everything back. BUT, PLEASE TEST that everything works and all lights blink and flash appropriately before re-assembling the mirror housing.
Disclaimer: I DO NOT TAKE ANY RESPONSIBILITY FOR ANYTHING DAMAGED OR INJURIES, THIS IT A DIY PROJECT.
Thanks Danny for helping me with the instructions, I do not know if this applies for the C-Class, so check out the bulbs prior to doing the project. Hope this helps. Happy Modding!
-Vik
TIME FOR A FIELD TRIP
To see if you car is able to do this mod, look at your driver's side mirror, make sure you can see the small amber bulbs, they should look like this picture. 3 going in a straight line, and 3 going down the side, making a "T" If you want to do the 3 bulb mod, change the white bulbs only. If you remove the yellow bulbs, it will not operate. If you want to do the 6 bulb mod, then change both the yellow and white bulbs on the diagram i quickly did. I hope this helps, PM me if you need any help.
What you need:
-Vik
W209 - W163
Go here....
https://mbworld.org/forums/showthrea...ng+side+mirror
It has a diagram of how your bulb placement should look, if it looks this way then follow my instructions... like i said i do not take any responsibility if anything is damaged...
-Vik
-Vik
