Exhaust Upgrade for W203
C320
I have a 2001 C320 and want to change the exhaust to either a single outlet with dual tips or dual outlets. After some research I find I can replace the stock muffler with the single or dual pipes that are part of the muffler. along with changing the lower valence. My questions.
. I have not looked under the car yet, so is it a simple process of removing the stock muffler and bolting on the new? Is the stock exhaust 1 piece and I will have to cut out the muffler and weld in the new one?
. Is the valence replacement a simple bolt on also? If I go with the single outlet will a valence from C32 bolt on with no modifications?
If I go with the dual outlets I know I will have to search the aftermarket for a valence.
Thanks ...
Thanks ...
2003 MB C230K Sports Sedan
Re: Exhaust Upgrade for W203
Thanks ...
Thanks ...
If i were you i would go with the Eisenmann race.. No valance modification needed and you get the single outlet with the dual oval tips... Beautiful sound..
-Alex
r171
if you use a brand suck as carlsson, brabus or lorinser for exhaust, you wont have to change your rear bumper.
you will need to cut off the old muffler to install a new one. you wont be able to do it yourself
