Speaker Grille's on the door
C230 Sports Coupe
how do you remove them??
Also does anyone know the part number for bi xenon projector headlights? or where i can get them? or a price? or any info at all? thanks
1 Post
2002 C230 Coupe
Re: uhhhhhhhh
Originally posted by blek
so i have to remove the entire panel to replance one speaker?
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
1 Post
CLK Coupe 200 Komp 53 Plate
What you need to:
1. Pull out the SRS badge and remove the star screw
2. Under the door arm rest there is a cover, popit off and remove the screw
3. Drop the window
4. slide off tweeter grill cover
5. lift panel carefully, not to much force as you may break the grill like they did when they done my window tint.
6. Then once its prized off remove the wire that connects the door release and you should be fine
Let me know how it goes
3. Drop the window
