W203 Cluster Removal
Old Jun 19, 2003 | 08:01 AM
Twincharge's Avatar
Hi
Can anyone tell me how I can remove the Instrument Cluster from a C-Class W203? This is the VDO cluster which has two little slots on each side. I Know this all comes out in one piece (Including the outer cover which has the stalk on the left) but how is it done?
Nad
Old Jun 19, 2003 | 10:46 AM
amiras's Avatar
11' E-350 BlueTec
I saw Steve remove it and he used a special Mercedes tools. He inserted it into the 2 holes, the he turned them (i think clockwise) and then removed the hole dash. It's a 10 seconds job with the adecuate tools. I don't know if you can do it with something else or not.
Hope this helps !
Angel
Old Jun 19, 2003 | 11:40 AM
Twincharge's Avatar
Angel
Thanks for the reply. Do you know if the Mercedes Tools used were the old C-Class (W202) Cluster removal hooks? I have a pair of these but thought the W203 needed something else? The W202 Cluster simply sits in the dash, whilst the W203 appears to be clipped/locked in somehow?
Nad
Old Jun 19, 2003 | 01:03 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
You Can Use The MB Combi Hooks that will release the combi on the W203 Insert them L/R and they will Release the clips and the combi will slide out.
