Summer feature window roll down key
Old Feb 2, 2012 | 02:52 PM
04mbc230's Avatar
2006 C230 Sedan
Just wondering. Is there a fuse for this component.
Summer feature window roll down with key.
This is where the IR key can roll down the windows from outside in conjunction of the black small box on the driver's droor.
If there is a fuse, please advise.
I recall it working with both keys and now it doesn't anymore. I do recall having the software upgraded at the dealership, could this have been turned off from the new software by mistake with star?
Old Feb 2, 2012 | 02:58 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
I believe that no, it would not be turned off. Most likely the receiver in the door isn't working anymore. Do a search - this has been the subject of several threads.
Old Feb 2, 2012 | 03:07 PM
04mbc230's Avatar
2006 C230 Sedan
Did a search. Nothing about fuse. That is why I asked. I was hoping there is a fuse and it makes things easier, now more than likely it's a dead sensor. Doubt I am going to fix it since it will cost a leg and I rarely use it.
Old Feb 2, 2012 | 03:50 PM
tommy's Avatar
It is too bad that it's not something simpler like a fuse. I guess it's just another example of Mercedes' excellence in engineering.
Old Feb 2, 2012 | 04:15 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
The feature is stupid and has always been hit or miss with my car - and my sensor was replaced under warranty. You have to stand right at the door to get it to work, what's the point?
Old Feb 2, 2012 | 04:29 PM
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
and press it over and over again making your self look like an idiot as your car locks and unlocks over and over, lol
Old Feb 2, 2012 | 06:02 PM
contact148's Avatar
2003 c240 4matic wagon
mine works from max 8ft away but allways works BOTH driver and pass side doors 03 c240 4matic wagon all 3 keys work
once when the sun was just right the driver door would not work but later it was fine
its really pretty useless
Old Feb 2, 2012 | 06:37 PM
04mbc230's Avatar
2006 C230 Sedan
I tried it again, but this time, I tried it while it was in my garage.
What do you know, it worked. First try. Rolled up and down.
So now I am thinkiny, it has something to do with the sun. If recalls, the day it didn't work was when the sun is full blown on the driver side. In the garage, no sun and dim.
This works with the ir receiver which in oart has to receive light signal. Too bright might present the ir signal from receiving.
Now, the real question is, why don't they make this wireless signal instead of the stupid ir light signal. Cost too much perhaps? I am sure it will be more useful with the radio signal.
Old Feb 2, 2012 | 07:05 PM
samaritrey's Avatar
Super Moderator
THE C350
Well they want it IR for two reasons
1. they want you to have a visual on the car to make sure you you don't hurt someone.
2. They want you to look like a ***** while using the feature.
Old Feb 2, 2012 | 07:18 PM
tommy's Avatar
LOL - I think that's in the owner's manual.
I guess I'm the only one to solve this problem so far.
