Latest ASP Pulley
I just installed mine a while ago and I noticed something right after I slid it onto the crank: the size seemed too big! Then I took it off and measured the diameter. Guess what, they went back to 8-13/16" again - this was their very first size that caused rubbing! Their second version was 8-11/16" which was fine; the diameter for the stock pulley is 7-9/16" BTW.
But I was like "what the heck!" and put it back on anyway and turned on the engine. After 10 seconds of running I saw an obvious rubbing mark on the water pump pulley.
They'll remachine it for you if you ask...
But it's good to let ASP know so they can make the change for their future pullies. Then mine will become a collector's item!
