Cutting Tein S-Techs
Old Apr 28, 2012 | 11:19 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
The front shouldnt require any grinding. The front fenders are aluminum - which means they should be SUPER easy to roll. Have at it - you can make TONS of space.
Old Apr 29, 2012 | 04:19 AM
phister's Avatar
06 C230 SS 6spd
Just be careful not to cut to much cause if you do and go to low you can rub the springs and eventually rub the frame. I went to low and noticed my tire was rubbing the frame and wore some paint off. I'd start with a quarter first.
Old Apr 29, 2012 | 05:55 AM
JFarhanbod's Avatar
2003 C230K Sedan
good idea ill cut another 1/4 coil off in a couple of weeks and see how low that takes me and if it isnt low enough ill do another 1/4 after.. better to be safe than sorry + its pretty easy, only thing that sucks is taking the spring off and putting it on
Old Apr 29, 2012 | 08:05 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
The sport springs people are referring to are the ones from 2005-2007. All the so called "sport" springs (even the c32 springs)between 2001-2004 in the US had the fubar height back then because of the bogus US bumper height requirement.
Also from what i remember cutting the springs increase the spring rate, not the other way around.
Old Apr 29, 2012 | 03:24 PM
phister's Avatar
06 C230 SS 6spd
Lol I was thinking of spring heating to lower the car I think when the spring rate is lower.
Old Apr 29, 2012 | 06:52 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
nah...heating the spring i think just breaks it down...weaken the tensile strength of the metal. definitely wouldn't recommend.
Old Apr 30, 2012 | 03:24 AM
  #32
Benzos4theteam's Avatar
2001 C320
OP since ur gonna go out and cut the anyways instead of cutting them , shrink them?
my friend got "clamps" to hold 2 or 3 of the coils of his spring into 1 thus making the spring shorter, and the car lower, why don't you clamp your car?
1) it won't cause permanent damage
2) it will drop your car even more.
win win situation.
Old Apr 30, 2012 | 03:32 AM
  #33
JFarhanbod's Avatar
2003 C230K Sedan
im sorry but that sounds even shiestier than cutting em.. cutting em isnt even that bad
