WC230 Sport coupe 2005 transmission help
Old May 18, 2012 | 12:22 PM
alexxx704's Avatar
So been here lurking a while and now have a real issue so here is the deal I just hit 100k and now I shift and sometimes about 3-4 times a week now my cars esp exclamation mark light will come on i will feel a lack of power to the wheels and the rpm will go up i just shift to another gear and usually it is fine. Any I deas what could cause this besides a bad clutch?
Old May 18, 2012 | 12:51 PM
alexxx704's Avatar
no one has even viewed it yet so anyone have a idea or similar problem?
Old May 18, 2012 | 01:29 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Lots of things. Have you had the dongles put on the cam sensors to prevent oil wicking into the wiring harness? Replaced the $12 hose?
Check engine light on? Any errors?
Old May 18, 2012 | 02:11 PM
alexxx704's Avatar
no errors mb replaced the hose themselves as part of a campaign and I have no idea about the dongles. I did get it serviced right before this started happening. no CE Light just I shift and the esp comes on i still get some power transfer but it feels like I am driving on a sponge liike only part of the power is going to my wheels.
Old May 27, 2012 | 11:27 PM
alexxx704's Avatar
So just too let you guys know it happens in 4th and 5th gear doesn't matter weather i am reving high or driving normal only happens every once in a while and is starting to happen more frequently any help would be greatly appreciated also the engine has started to make a clicking sound only when it is sitting idle once i am going it goes away.
Old May 29, 2012 | 02:08 AM
It's difficult to determine exactly what you are experiencing from your description.
A bad wheel sensor causes a wierd issue when accelerating hard, the esp abs etc blinks...
maybe a video explanation would help.
