HELP! - Tenzo Tracer
Old May 26, 2012 | 06:06 PM
TTR's Avatar
TTR
R129 SL500 & W140 S500
I just bought some Tenzo Tracer's (http://www.tenzoracingsports.eu/felgi.html) in the 18". When I took them to have it installed the guy said that the CB is too small but the car's CB is 66 whereas the rims are 73.1. He said the "dust cap" was blocking him from putting on the rims. I am at a complete loss what to do.
Old May 26, 2012 | 07:20 PM
phister's Avatar
06 C230 SS 6spd
He is probably talking about the bearing cap on the front. Even though the bore is larger is might not be deep enough for the front hub for the wheel to sit. The center cap hole is usually smaller than the bore so the cap is probably hitting it not allowing it to go any further. You can probably take it to a machine shop and have it bored all the way through but then you can't use the center caps.
