Front Outer Cv boot
Old May 29, 2012 | 11:59 PM
Pope's Avatar
c240 4matic
Front Outer Cv boot
I ordered the front outer CV boot for my 04 C240 4matic today. Old one was torn and throwing grease al over. Does anyone have a good walkthrough with pictures to DIY. Dealer wanted 550 bucks to replace and the part was only 40 bucks. Figured this was a more economical route than paying a fortune.
Old May 30, 2012 | 07:31 AM
contact148's Avatar
2003 c240 4matic wagon
make sure the joint itself is not worn or dammaged as if it is replaceing just the boot will just delay failure
I did both front axels on my 4matic i had a indy shop that just does axels/cv joints
they told me the hub bolts were VERY VERY tight and hard to get off search my name i did post the cost
if your in a major city there should be an axel shop
Old May 30, 2012 | 09:27 AM
Tri-Star's Avatar
C320 4Matic & GLK350 4Matic
I had an indy axle shop replace the boots and cv joints on my 4matic last year.
Old Jun 1, 2012 | 09:43 AM
Pope's Avatar
c240 4matic
Ordered the CV boot online for 40 bucks. Also while I was at it changed the outer tie rod end. Noticed it was very unstable once I got the car jacked up. It was a relatively easy job. Since I only had to change the outer boot I did not have to pull the entire axle, which was pretty nice. Tie rod ends=very easy to replace. For those two jobs, Stealership wanted almost 1000 bucks to replace.
Heres what I paid:
$65.00 for outer tie rod end
$40.00 for Outer CV boot kit
and the kicker
$15.00 for beer. (One beer for every bolt I took off )
Total savings $880.00
If anyone has to replace eother of these and needs some instructions let me know.
Old Dec 16, 2012 | 10:43 AM
Brian McL's Avatar
So...how did you replace the outer boot? I mean, how did you take the CV apart on the car? I got the whole CV detached but can't get it out of the transfer case (it will not come out no matter how much pulling I do). Since all I need to replace is the outer how do I pull that appart so I can slip the boot on?
Old Dec 16, 2012 | 12:42 PM
contact148's Avatar
dont pull the joint
you need to get a pry bar and place it between the transaxel and the cvjoint body
the axel shaft is held in by a circlip
