where did this bolt come from?????
2003 c240 4matic wagon
so today my daughter found this bolt on my driveway
2003 c240 4matic wagon and everything still works......... no rattles......
so whats this bolt from?? its for sure an MB bolt
hmmmm. Its a stud.....weird that is a inverted torx head. Maybe specific to the 4-matic c class. I would also guess exhaust manifold bolt.
Second thought, that wouldnt make sense because there would be a 10mm nut on the end, and the end is rusted.....indicating nothing was on the end. It must have been sitting around in your undercarrage, or subframe for a while. Any previous exhaust work?
well i did have the cats replaced under warrenty 2 years ago
its so tight in there I cant see if an stud is missing from the manifold ill try a mirror tomorrow
i think it IS an exhaust manifold stud 272 990 00 05 maybe???
2007 W204 220CDI Classic Sedan
May have been dropped by a mechanic when doing a previous job on a hard to retrieve position then fallen out when eg you washed the car .
In the absence of new advice ,have a look around where previous work has been done.
