H&R Coilover question
Old Jun 3, 2012 | 12:39 AM
BlkBenz8's Avatar
07 C230 (sold) 2009 E63 AMG (SOLD), 2015 E 63 AMG S
Just happened to install new tires all around.
F:225/35/19
R:265/30/19
15mm spacer all around.
& my tires are hitting my springs badly, I dont want to drive because my tires will literally melt away. Is there a DIY coilover adjustment thread?
Or maybe I can go 20mm to avoid the spring? Im not trying to move my car at all.
Old Jun 3, 2012 | 01:32 AM
phister's Avatar
06 C230 SS 6spd
You want to adjust the height? Just use your tool to loosen the perches. Also if you're running neg camber in front get it realigned.
Old Jun 3, 2012 | 12:57 PM
BlkBenz8's Avatar
I need to do something ASAP. Im very limited in tools, & is the high adjustment hard to do? What tools are needed? I was thinking of getting a bigger spacer as of now just to push the tire away from the springs. Ive never had this problem with the front tires.
Old Jun 3, 2012 | 01:54 PM
phister's Avatar
06 C230 SS 6spd
H&r should've supplied the tool to loosen the perches, it looks like a hook. Just loosen the perches then spin it to adjust the height.
Old Jun 3, 2012 | 01:55 PM
phister's Avatar
06 C230 SS 6spd
It'll look like this
Old Jun 3, 2012 | 01:57 PM
phister's Avatar
06 C230 SS 6spd
What is your current offset? From the looks of your car you might rub the fender if you go out further and you'd need to roll the fender.
Old Jun 3, 2012 | 07:03 PM
mtnman82's Avatar
'16 E350, gone: '03 c230k
You could always go with 255's in the back...
Old Jun 3, 2012 | 10:09 PM
BlkBenz8's Avatar
These euros have w204 offsets.. so they were at et42 et45 nd with 15mm spacers all around so et27 et30. My prior tires were the same size bu generals these hankooks rub TOO much.
BlkBenz8's Avatar
Old Jun 3, 2012 | 10:12 PM
BlkBenz8's Avatar
I do have rolled fenders all around, i was thinking about pulling them a bit. Are your fenders pulled or did you have to sand down any part of the wheel well?
The problem is in the front, dont rub in the rear.
Old Jun 4, 2012 | 12:16 AM
ABlatzheim's Avatar
Mercedes Benz C280
i know you don't want to do it but phister is right..If you are running negative camber in the front you are going to have t oget it adjsutsed.. You also are going to come up a little higher with the 19's.. I am currently running ksports with 9.5 inches in the rear et35 and 8.5 in the front et 32.. No spacers dropped 2/3 of the way down.. I would go with a different tire up front.. i have michelin pilots sports and the front are strtched pretty good so I didn't rn into the problemt you are having .Good luck.. I wiil hit you up with some pics of my front and the exact tire dimensions in the front... By the way my fenders haven't been rolled in the front or rear.. https://www.facebook.com/#!/photo.php?fbid=3141764833553&set=a.1556449881670.2 065242.1547919286&type=1&theater
Old Jun 4, 2012 | 12:52 AM
phister's Avatar
06 C230 SS 6spd
You can get away with 20mm spacer up front since it'll make it +22. You might have to pull it slightly but I doubt it. I had +20 on my previous setup and all I did was roll the fender and it cleared. I rolled and pulled like a b!tch lol had to get +15 to fit. Also be careful with the wheel well there's not alot of space from the liner to the car body. I actually rubbed a hole in the liner and was rubbing paint off the frame. I have to get 215/40/18 in front to go lower now and clear my springs and the perches. So going with spacers will clear your issue but I'd match the rears too make it flush all around.
Old Jun 4, 2012 | 09:35 PM
BlkBenz8's Avatar
If i go with 20mm spacer, ill have to pull the fender for sure because theyre already rolled. Unless i have to tailor the wheel well?? Look at my second picture, can that sharp plastic be sanded down? I never had a problem with my front tires even with my ride height being a little low.
Old Jun 4, 2012 | 10:02 PM
ray2943's Avatar
2006 C230
I had a similar issue when I installed my coilovers. I couldn't lower my front because the spring would hit the tire. I installed 12mm spacers and that didn't help. I was only able to lower the car a little bit more. I ended up changing the inner barrels on my front wheels a half size smaller and that fixed my issue.
Old Jun 5, 2012 | 01:58 AM
phister's Avatar
06 C230 SS 6spd
You can grind it down. Also when you look at the upper strut bolt on the coilover body is it all the way pushed inwards (towards the strut). This bolt can adjust the camber so if its all the way towards the stut youre running negative camber. I had to loosen that and the two lower strut bolts and pulled it out some to give clearance and not run so negative. Most coilovers make that bolt hole oval shaped to allow for the camber adjustment. When its loosen you can hold the upper hub and push it back and forth.
Old Jun 5, 2012 | 09:27 AM
BlkBenz8's Avatar
Sounds resonable but thats not an option for me at this point.
so I need to correct my camber up front, space it and grind down the wheel well....if all this doesnt work then I will simply and unfortunately have to raise the car. I wish I had the tools to work on my car but im very limited so ill have to go to sonic ms for this. What camber are you running all around?
Old Jun 5, 2012 | 10:08 AM
phister's Avatar
06 C230 SS 6spd
i forgot what my rears are I keep adjusting them lol I have a camber level to adjust every time I mess with my camber in front and rear.
Old Jun 5, 2012 | 12:03 PM
BlkBenz8's Avatar
Dude your rear fender/wheel fitment is on point. Im running a -1.9 in the rear and going upgrade the spacer to 20mm. Im guessing you had to do a **** ton of pulling and rolling on the rear. Question, when pulling the fender does the paint run the risk of coming off and peeling?
Old Jun 5, 2012 | 01:35 PM
phister's Avatar
06 C230 SS 6spd
You really have to make sure you heat the fender properly when pulling. You have to do it in phases to gradually pull it out or it'll get uneven and wavey. I no longer have the lil flat edge on the fender its all pulled. Had to get 18x10 +15 to fit. Might rebarrel the rear and push it to 18x10.5 in back.
Old Jun 5, 2012 | 01:54 PM
ABlatzheim's Avatar
Mercedes Benz C280
i noticed that you have def pulled the crap out of the rear. It looks absolutely awesome but i would be worried if I ever wanted to go back to stock.
Old Jun 5, 2012 | 02:51 PM
C_DirtyTwo's Avatar
a land yacht.
I had the same issue with mine. I went with a 225 up front on an 8'' wheel and I have a 32 offset with a 10mm spacer=22 offset was the magic number for me. My fenders arent rolled or pulled
however with the same offset and an 8.5'' wheel I had the rubbing on the coil
Old Jun 5, 2012 | 03:53 PM
phister's Avatar
06 C230 SS 6spd
I'd never go back to stock on this car lol In any case I'd just buy another car and use it as my beater. I'm already on the look out for one right now. Something with good gas mileage for my long road trips that I take.
Old Jun 5, 2012 | 11:17 PM
BlkBenz8's Avatar
So tomorrow will be the day I adjust my front camber. Luckily Im employed by mercedes benz so I can get alignment done there.
Old Jun 5, 2012 | 11:19 PM
BlkBenz8's Avatar
Phi- Do you have any close pictures of your fenders? Your front fender still has the squared look but the rear is fully pulled correct?
Old Jun 6, 2012 | 01:36 AM
phister's Avatar
06 C230 SS 6spd
Front its pulled too
