W203 Depo Retrofit Questions
05' C230K
Hello so I have depo projectors installed in my car for about 5 years and I believe the projector ballast warped or went bad because the lights scatters horribly across the road now. I've tried adjusting the ballast but it doesn't get anyone better. I was wondering has anyone done a retrofit with s2000 ballast or morimotos? Just wondering on the difficulty level of getting this done with Depo aftermarkets? Any input would be appreciated!
Thanks!
Thanks!
06 C230 SS 6spd
Ballasts are what controls hids. youre talking about the projectors itself, it might be the reflective shield and not the glass. There are DIY on here of people retrofitting different projectors. Most use TSX, FX-R, or E55 projectors. E55 projectors are the easiest because they actually bolt right in to the 4 mounting holes. The others require a little bit of modification. Just use the search function because this topic has been discussed numerous times.
