Hardware question - Undercarriage covers (C240 2001)
2001 C240
One of the covers under the car and behind the transmission is supported with 2 small brackets. I found one of them to be loose (flapping around) while fixing another problem. Upon inspection I discovered that the rectangular press-nut in the chassis was missing.
Would anyone have a spec /source on these press nuts, or am I stuck with the dealer on this one? Not sure of the bolt spec, but was using an 8mm socket on it.
Many thanks in advance !
Dave
Dave
2001 C240
![Thumbs up](https://mbworld.org/forums/images/icons/icon14.gif)
Yes, indeed they do !!! It's listed as 'clip nut for engine compartment lower shield' for a whopping 72 cents. Nothing like finding the real thing.
I'm speechless - thank you so much. I'm a newbie to Mercedes, but what a great resource here. This forum has already solved some routine problems for me right off the bat(windshield washer & cd player). Nice to know I started at the right place!
Thanks again, phister !!!
