A/C makes squealing noise?
Old Jun 26, 2012 | 11:14 AM
Hogger's Avatar
2009 ML350, 2007 GL450, 1963 GMC, BMW 325i
So. it's A/C weather, and mine has been acting up.
Without the A/C on, the car idles, drives, and sounds fine.
Once I turn the A/C on if sitting at idle, I notice the RPM's come down maybe 100 or so, which is understandable, but it also starts to make a squealing type sound, particularly if I tap on the gas it does it pretty loud. Sounds like the belt is loose, but I just replaced it, and it's still doing it.
At higher RPM's it doesn't make the sound. And the system blows nice cold air.
Could something with the compressor pulley be going bad?
Old Jun 26, 2012 | 11:31 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
https://mbworld.org/forums/c-class-w...1-8l-c230.html
See if that helps. You're definitely not the first to have this problem.
Old Jun 26, 2012 | 12:17 PM
Hogger's Avatar
Ya, there we go. Thanks
Old Aug 11, 2014 | 06:27 PM
Burgermeister's Avatar
c320
Forgive my ignorance, but does this issue apply to the 2002 c320 as well? I have the same squealing/squeaking when idle and low revs.
Can anyone confirm if this was covered under a recall or how much the dealer would charge for replacing?
Old Aug 11, 2014 | 10:05 PM
onehighfocus's Avatar
2014 c250
Or possibly the alternator pulley?
https://mbworld.org/forums/c-class-w...ditioning.html
Old Aug 11, 2014 | 11:01 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
Most likely. Hogger has since replaced his alternator pulley, too.
