contiental dws question
Old Jul 11, 2012 | 12:31 AM
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
the tire guy said since the dws are bigger he needs to adjust the rear toe so they fit...does this sound right?
i gave this guy my specs on paper for the alignment. he totally made my car pull to the right. the left toe is at .06 and the right is .02.. haha gotta take off of work now
good tires nice and smooth
Old Jul 11, 2012 | 10:41 AM
polarbexar's Avatar
Veteran: Air Force
2025 Mazda CX70 Turbo S, 2015 G550
What size are you running? If its the stock size then no, no change was needed. Even if you plus sized I can't really see the need for it. I ran those tires on my C and my GLK, and on my C the rears were toast at around 25k miles but I got nearly 65k on the fronts. The fronts still had the "S" showing but the shoulders were a little worn. Sounds like the guy waisted your time...
Old Jul 11, 2012 | 11:02 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
I run DWS at stock size, this is my second set. No adjustments are necessary. My last set lasted 41k on the rears but the front shoulders were worn around 38k. Rotating across the axles helps somewhat.
Tires are great.. Super smooth and very quiet, also very good grip wet or dry.
Old Jul 13, 2012 | 07:02 PM
Norwichdelta06's Avatar
2007 c230
were you sitting in the car when he aligned it?
Old Jul 15, 2012 | 12:38 PM
no i found out my right rear tire is bald which is causing my car to pull to the right
is their any way i can get new front tires from cassidy tires since their is uneven wear?
