Carsoft Or Multiplexer 7.4 on 2005+
Old Jul 13, 2012 | 07:40 PM
Scott N's Avatar
Hey all, first post for me here so be gentle.
I just picked up an Alpha Bid Mulitplexer. After MANY MANY hours of "figuring" out how to get things installed and how to get it connected to my OBD II via USB cord, I'm having issues with "modules not being loaded" or "data not being received" on my 2005 C230 Kompressor Coupe with the software. I specifically need it to read the airbag codes and the air conditioner system.
I really, really don't want to go to a dealership. I can fix it if I just know where to start. Help me Obi Wan Kenobi, you're my only hope!!
Scott
Old Jul 14, 2012 | 03:18 AM
phister's Avatar
06 C230 SS 6spd
I dont think the multiplexer reads airbag codes, you might have to go to dealership or an indie shop that has a STAR diagnostic reader for MB.
Old Jul 14, 2012 | 10:15 AM
NYFlapjack2's Avatar
C230K - sold
Might want to check I thought the Alpha bid carsoft only covered up thru 2004. I thought it was something like in 2005+ Mercedes changed the software and it wasn't as easy to crack...
Old Jul 14, 2012 | 10:17 AM
Sergey_'s Avatar
W203 C180K Sport Coupe 2003
Carsoft 7.4 works correctly only with real COM port hardware. Any USB to COM converters don't work. Some USB converters such as FTDI try to work, but do it very bad. I can read and erase general airbag and air conditioner errors on my 2003 C180 Kompressor Coupe. I have mini PC on Intel Atom mini ITX board with real COM port especially for Carsoft 7.4 in my garage. But Carsoft declares only MB until 2004 year support.
Old Jul 14, 2012 | 06:25 PM
Scott N's Avatar
The USB is exactly what i had to do to get mine to work. It reads some tests, just not the ones i need (AC and AIRBAG). Do you think if I find a PC with a com port that it will fix my issue?
Old Jul 15, 2012 | 04:40 AM
Sergey_'s Avatar
With USB/COM converters my Carsoft says "module not found" after "communication under construction" for several really present modules. But with real COM port Carsoft founds all my car's modules. I think you can try to work with real COM from PC or old laptop.
Old Nov 8, 2012 | 07:53 PM
DG83 C55's Avatar
05 C55
So this will allow me to reset SRS lights as long as I use an older laptop with a RS232 port?
Damian
