Headrest issues
The mounting mechanism looks complex, with some sort of tightened clamp with a nut in the middle.
Here's the back of the headrest. It looks like part of the plastic broke off in a center piece that would've formed a hole for mounting.
Any ideas on how to get this back on in the condition it's in? I tried superglue on the two "hooks" coming out of the mounting spot, but it didn't stay.
That backrest piece that's still attached looks like it can slide down out of the way,.... you could probably bolt on metal plates on both side of that black plastic piece that broke off the front piece,... Once the fixed front part is bolted back on, it looks like you can slide that back piece back in and have it hook into the front.
But considering that a headrest is also a safety feature and has been engineered to act a certain way in an accident, I think you're better off buying a replacement. Salvage yard might be a good source but it'll be tough to find that colour.
