Problem with C55. Battery/Alternator Visit Workshop.
Old Jul 21, 2012 | 01:26 PM
GT-ER's Avatar
2005 E55 AMG
My friends C55 turned on a red display with the message "Battery/Alternator Visit Workshop". His car eventually ran out of energy from the battery and turned off. I told him to check out the alternator and he sent it to a mechanic and the alternator was bad and it was replaced with a reman and they installed a new battery as well. As soon as they turned it on it still had the error message. After a few tries the error message went away and the car was working fine....for one day. Then it had the message again and the voltage was low ( 11's ) with the car on, then it went away...again. It's been on and off.
What could be doing this? Is there a battery control module in this car? If so, where?
Old Jul 21, 2012 | 01:53 PM
phister's Avatar
06 C230 SS 6spd
might have a grounding issue somewhere. make sure all the connections to the battery and alternator are clean and secure. even a slightly loose cable or exposed wire can cause headaches and gremlins.
Old Jul 21, 2012 | 05:12 PM
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
the battery is proobally bad
Old Jul 21, 2012 | 05:39 PM
MBfinatic's Avatar
e36 318i, 2004 sti
Either what they both said or something isnt going into sleep mode and draining the battery. Parasitic drain test!
Old Jul 21, 2012 | 05:44 PM
GT-ER's Avatar
2005 E55 AMG
I checked, couldn't find any. It also started since the alternator went bad.
It's brand new.
How do I check this?
All this started one day when the alternator went bad. After that it's been on and off.
Old Jul 21, 2012 | 05:48 PM
MBfinatic's Avatar
e36 318i, 2004 sti
http://flashoffroad.com/electrical/B...teryDrain.html
Old Jul 22, 2012 | 08:02 AM
GT-ER's Avatar
2005 E55 AMG
Thanks.
Anyone know if this car has a battery control module?
