SWAY BAR QUESTIONS FOR 2002 c240
Old Jul 26, 2012 | 10:57 PM
mrfilthybenz's Avatar
2002 C240
Im looking to by H&R sway bars for the front and back of my 2002 c240... im finding two different sizes for the front 12mm and 10mm?? how do i know which to use? and also, which size is needed for the rear?? also, does anyone have any insight on Evosport under drive performance pulley>? let me know what you guys think
Old Jul 27, 2012 | 12:22 AM
phister's Avatar
06 C230 SS 6spd
You'll need 10mm for the sways. If I remember right c32 and post facelift use the 12mm
Old Jul 27, 2012 | 01:07 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
AMG w203s use 12mm fronts sway bar end links while non AMG w203s use 10mm front sway bar end links.
The rears for both are 10mm.
Get the 10mm and you'll be fine!
Old Jul 29, 2012 | 11:30 AM
MW_ATL's Avatar
'02 C230 Coupe (Me) '03 SLK320 6MT (Wife)
It really depends on what you want to accomplish. If you are just wanting to replace your stock setup, then the 10 mm would be the way to go. On the others hand, if you want to change the feel of the car you can go a bit thicker with either or both. There are several threads on what you can do...and some pretty knowledgeable people on how the changes will work to change the handling and feel of the car.
