brake caliper / rotor
today I checked the rotor and appears that caliper is following the rotor as it rotates
please check the video i got :
does it mean that my rotor became warped again?
thank you!
The rotors could be warped slightly. Enought to see the caliper moving with the rotor but not enough to feel the pulse in the pedal.
hmm... i'm not sure if its fine or bs...
going to jack the wheel and spin it in assembled condition to check if it makes any difference ...
then I loosen the bolts a bit - no issues
I loosen more and started to notice that wheel spins with some extra effort at some point compared with tightened bolts
I removed the wheel and noticed that brake rotor is not siting firmly - it is mounted only with one bolt to the hub and on opposite side it is not siting tight and close to hub
So I would say it may be a cheap rotors that is not 100% fit the hub if not tighten with bolts to the hub or the hub was not cleaned before new rotor installation, or 1 & 2 together
And it appears to be not that hard to replace it DIY so next time i will go for good rotors and ceramic pads
thank you for all responses / help
