HELP W/ C230 FRONT *PIX*
good luck
did you have before leaving the parking lot? That's some serious damage to your front lip; you're going to need an entirely new bumper assembly. Based on the force required to do that much damage, my guess is that you've lost at least a couple of the plastic bolts for the belly pan that is currently hanging down. Either immediately today assess the damage and get new parts, or remove the belly pan temporarily until you get the new parts. As is, it's going to keep hanging lower until it wedges itself free, and you don't want that.Agree that it's probably the washer fluid, but you don't want that leaking all around expensive wiring. I wouldn't drive this car any more the way that it is without a full inspection of everything.
