Probably the only C350 w203 with LSD Quaife
C350
2013 ML350
Hi Just to share pictures about a Quaife install after few months of research and work close with a machine shop to fit in the diff.
cheerAttachment 241630
Attachment 241629
Attachment 241629
C350
It was almost 750$. I took the qdf7v because it's a 10 bolts like the diff on the c350 after that we have to slot the hole almost 2mm to keep the bolts pattern for the ring gear. We had to cut and and open the seat for the drive axles (let holes were you insert the axles). For the the bearing it have to be turn to reduce the diameter and one side need a ring and the other have to machined to be at the right place. The ring gear seat have to be reduce to fit. This is almost what we have to do to fit the LSD
2013 ML350
