ticking noise
Old Jul 23, 2003 | 12:12 AM
c230_kS's Avatar
ticking noise
any c230k sedan owner has heard the ticking noise when it's idle?
Old Jul 23, 2003 | 02:11 AM
webhost's Avatar
2003 C230 Coupe
It is probably just the fuel injector "clicking" you hear.
shrugs
Old Jul 23, 2003 | 03:30 AM
c230_kS's Avatar
so is it normal or something that can be adjust so it makes less noise
Old Jul 23, 2003 | 07:41 AM
viper's Avatar
It should not be considered normal. Take it to the dealer and tell him you want it fixed.
Old Jul 23, 2003 | 08:51 AM
Tariq's Avatar
S500 W223 2021
Its normal...
Specially in V6 engines...
This ticking comes sometimes not always...
but dont worry about it... because i faced the same and the munifactuer or MB V6 users feed me that its normal.. and it not ticking always.. i guess this comes when the engine get warm
Old Jul 23, 2003 | 01:08 PM
p010sp0rt8's Avatar
2008 Cayman S / 2002 C230
i have the same problem with my coupe in the mornings.. i've always attributed it to the car warming up and figured that it's part of the whole coupe sounding like a lawnmower underwater thing
Old Jul 23, 2003 | 01:21 PM
czachari's Avatar
2003 C230
Could also be the hydraulic valve lifters
But those only make noise when they are worn out. This should not be happening on a new engine. It's probably the injectors. I don't think it's an issue unless it's accompanied by other problems.
CZ
Old Jul 23, 2003 | 05:48 PM
spacetrain's Avatar
03 C320 Sedan
re: ticking noise
For the car that I had before (2001 C320) the ticking noise came from the purge valve. They replaced new ones and noise went away. I suggest bringing it to the dealer and have them check it out...perhaps mention to them if it could be a purge valve.
Thanks.
Old Jul 23, 2003 | 08:13 PM
BenzOwner02's Avatar
Yes the noise you hear is the purge valve. If you do a search on here you can find many topics on this issue. What shocks me is that they still have not solved this issue on the 2003 models. What a disappointment in quality
