Mysteriously Car wont start, Need expert advice.
Old Sep 23, 2012 | 05:20 AM
hahaitzmickey's Avatar
C230K Sedan
Here is a new problem. Maybe someone can help me out. Last night My buddy and I put in a new alternator and a new spark plugs into the car.
After we had secured everything back. We started up the car. It turned over and made this flapping noise and popping sound. Like it was from inside the engine. I shut the engine off quickly. I pulled the spark plugs back out to inspect inside the combustion chamber. Nothing was found. I looked all over the engine bay for that noise. Nothing was found loose or missing. After putting everything back together. We decided to start the engine agian once more. This time. You can only hear the start kick on but the engine does not turn or jump. So we check everything. Fuel pressure is good. Spark plug is making spark. Starter is spinning. Cams is spinning. I can't get my engine to start now. I can't figure this out. Can anyone have a clue where I should start looking? I checked the fuses, they are all good also. When I turn the key all you can hear is the starter spinning and nothing turning over. But the belts do rotate around. It doesn't even shut off until you turn the key off. Battery is always reading 12.58v. Need help anyone have any idea?
Old Sep 23, 2012 | 05:26 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Did you check the timing chain?
Old Sep 23, 2012 | 10:30 AM
C230K Sedan
Yea , cams are spinning .
Old Sep 23, 2012 | 11:14 AM
boschk's Avatar
2006 CLS500 - Iridium Silver w/ AMG Sportline
Read the ECU and see if ther are any codes. Sounds electrical, not mechanical.
Old Sep 23, 2012 | 12:09 PM
C230K Sedan
#F I hope timing chain didn't stretch or snapped.
Code is reading system bank 1 to lean and misfire in cyclinder 1
Old Sep 25, 2012 | 10:40 AM
wunderless's Avatar
2003 C240, 2013 GLK 250, 70 'cuda
Did you mix up the plug wires?
(Not sure that's possible but worth the ask.)
Old Sep 25, 2012 | 11:51 AM
C230K Sedan
No, its impossible to mix up plug wires on it. I found the problem. Timing Chain stretch, its out of timing. Needs new timing chain and tensioner and valves. This is a common problem with this car. So anyone who owns one , it is bound to happen soon once you pass 100k+ miles.
