Add-A-Circuit - Hardwiring Radar Detector
Old Oct 3, 2012 | 05:09 PM
Tri-Star's Avatar
C320 4Matic & GLK350 4Matic
I just purchased a new Cobra radar detector to help with my commute to and from work. I currently have the radar, the hard-wire kit and need to puchase a "Add-A-Circuit" to plug into my driver's side door fuse box.
Does anyone have any recommendation as to which fuse to use or info about the add a circuit. If anyone has a diagram indicating which fuse within that location is for, it would be greatly appreciated.
I was thinking of using a smaller ATM fuse since the radar only needs about 2-3 amps at most. Please comment!
Thanks!
Old Oct 4, 2012 | 03:54 AM
phister's Avatar
06 C230 SS 6spd
Why not hard wire to the cig wires
Old Oct 4, 2012 | 08:26 AM
Tri-Star's Avatar
I'd rather not splice into any existing wires and the hard wire kit provides just enough wire to reach that fuse box. It should be a simple plug in. I want to make sure that I have the correct fuses so that each circuit will run properly.
Old Oct 4, 2012 | 06:11 PM
benzmodz's Avatar
W203 slightly modified
The dashboard fuse area is just a generic outlet. It is color coded for factory assembly. Any position is the same.
Old Oct 5, 2012 | 09:42 AM
Tri-Star's Avatar
I got the radar hooked up & hardwired to the dash with the add-a-circuit. The only thing that could be better is that the radar I purchased doesn't have the option to change the LCD screen to orange like my old one did. I realized today that for an extra $12 I could have purchased the same detector with that option. Call me a perfectionist but darn it!
Old Oct 5, 2012 | 02:09 PM
Norwichdelta06's Avatar
2007 c230
http://www.blackboxmycar.com/
http://www.blackboxmycar.com/product.php?id_product=41
http://www.blackboxmycar.com/product.php?id_product=86
I bought this to hardwire my dash cam
