C180 Auto - Wont Start; No Dash Lights
I was searching for solutions to problem online but couldnt find anything, I wasnt sure if it was due to car being immobilized due to anti theft system or if it was due to some failed component or if it was aging key sensor(I just have one car key, so couldnt try another to isolate this)..
I kept struggling for a while and after reading some random posts on internet, I thought of disconnecting battery for a while to see if it helps.. The moment I touched the battery box to disconnect it, suddenly car lights came back on, along with dashboard lights. I went back in and tried starting the car and it started with instrument cluster showing ESP couldnt be activated due to a fault. I turned the engine off and it said 1 fault and showed the same ESP error. I tried starting again and this time no ESP error and it said "No Malfunction" on switching off this time, and I could just drive off without any issues after that.. Tried switching Off and On again several times but car worked well after that.
I am not sure what happened to the car momentarily and if I could run into such a problem again. Any suggestions or help is appreciated..
Thanks,
Abhi
Car Details: 2002 C180(W203) Petrol, Auto - Avantgrande; 77K Miles done
Follow instructions in owners manual for procedure on how to disconnect and reconnect battery,... otherwise you can damage the electronics in your car.
How old is battery,... date stamp on top of negative terminal. If more than 5 years,... it's time to change it.
Hi guys maybe u can advise me. Barney here, I've followed your site forums for some time and have enjoyed and learned stuff from the discussions over the time my wife has had the 2nd hand C180. Procured locally in immaculate condition in 2012, from a private seller with 97k kms on the clock for $14k. Everybody Happy!!!!!!
My wife's car is a 2001 C180 (WDC203)
Beautiful vehicle in all respects but it has cost me some dollars.
2013 New rotors and Bendix (low dust) pads which I fitted myself. $225
2014 $3.5k to replace the Variable valve timing gear
with a non genuine set up fitted by a supposedly reputable Mercedes Mechanic.New battery fitted by Bockman Batteries special price $220
Has been going great till a coupla weeks ago when it was announced the DASH lights and indicators weren't working!! 1930pm
WTF
I'ld had a coupla drinks, which was a mistake when I investigated the situation. Yep sure enough no dash lights, but the car did start and run fine down the road.
I knew I should have asked u guys first but was under pressure U know?
Work in the morning and all that crap!!!
Ok lets try resetting everything by, YOU guessed it disconnecting the battery
Don't ever ever do this EVER
It totally locked everything out of everything leaving me only one choice RACV which was no help at all and the car was loaded into a flatbed & has been @ the Mercedes dealer for the past 3.5 weeks for them to diagnose what I had already told them wasa dash instrument problem.
Anyway Today they ring to inform me that:
WOOHOO WE"VE found the problem and the fix is this:
New instrument cluster straight from Melbourne $2,875
Technician instalment (lobour cost) $574.62
I saidAnyone wont a non going immaculate 2001 C180????
thanks for listening will look forward to any all advise
ta
Alan
