Remove MAF??
Old Oct 20, 2012 | 06:26 PM
saviguel's Avatar
2002 C240/SPT
Remove MAF??
Hello everyone! I am having issues with my 2002 C240 and was attempting to clean MAF as this is one of the main things I saw related to MB staling, ideling and running rough. Well I was able to remove the plastic clip around the MAF assembly; I was also able to move the metal clip on the back but the plastic connector wow. Does one need special tool to remove this plastic connector?? Any tricks to work in this cramp space and remove connector is GREATLY appreciated.
Old Oct 20, 2012 | 07:23 PM
torake's Avatar
C180 Kompressor Wagon
Press tabs on short edges and pull.
No disrespect but if you are unable to disconnect the connector you might be better off leaving the job to a professional.
Old Oct 20, 2012 | 07:46 PM
saviguel's Avatar
2002 C240/SPT
Wow torake on my first post...nice welcome! No disrespect that is a comment that you should keep to yourself. But thanks for your input.
Old Oct 20, 2012 | 08:12 PM
SunnyRayToronto's Avatar
2003 C230 Sports Coupe, Paprika Metallic Red, Auto, Pano, Leather
"No disrespect",.... but did you try the SEARCH function? These cars are 10 years old,... lots of DIY on MAF.
Also, if you need individual help,... try being more informative,... like photos of which plastic clip or clamp you're having problems with,... plastic connector? Is that a wire plug??? Really, only one metal clamp that's a pain,... but as long as you have a cable operated hose clamp plier or really long needle nose plier, you should be fine.
Old Oct 21, 2012 | 10:27 PM
saviguel's Avatar
2002 C240/SPT
I did found several DIY but they did not go into the details of removing the plastic connector/wire plug I guess it's something assumed to be easy. Anyways I did get a couple of pointers that allowed me to remove and clean the MAF. Thanks
Old Oct 21, 2012 | 11:11 PM
MB plastic connector/wire plug generally have plastic ribbed tabs that you squeeze to unlock. For the MAF,... if looking from the top of the plastic connector/wire plug with wires going towards you,... you will find 2 little tabs along the side that you squeeze together.
Some MB plastic connector/wire plug have one tab-lock,... some have 2,... just look at the plastic connector/wire plug,... look for where the lock could be,... then you will find the ribbed tab nearby.
CRC MAF Sensor Cleaner,... aka CRC SensorKleen is what I would recommend.
Old Oct 22, 2012 | 07:28 AM
tommy's Avatar
2004 Civic Si. FWD for the Win!
If cleaning doesn't work (which is a fairly normal situation), AutohausAZ has good prices on replacement MAFs - I've bought a couple from them, and I haven't heard of any complaints with them. Luckily, as you've seen, once you get familiar with them, replacing a MAF is pretty straightforward.
