01-07 C230 on air
Old Oct 24, 2012 | 10:03 AM
evade's Avatar
No lurkers...
01-07 C230 on air
Anyone currently with an air suspension please post your set up and tech specs. I'm looking at how I can go air in the front. There are universal bags that will go over the shock body (depending on what shock/coilover size you're running), but I am not able to find out if they can be used with our stock top bearing. These cars use a v style coil spring, which is proving to be a pita to find anyone who makes a shorter spring. The coilovers out there for our cars just don't fit my needs for the fronts. Help/info/ideas please?
Old Oct 24, 2012 | 10:33 AM
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
pretty sure u need that air pump like the s classes do..which is like a couple grand plus everything else
Old Oct 24, 2012 | 10:39 AM
evade's Avatar
No lurkers...
? No, not what I'm searching for... There's a couple bagged 203's out there, one wagon on this forum. I'm on coilovers now and am looking at airex's suspension for the front. also looking for other info out there on any other set ups.
Old Oct 24, 2012 | 10:42 AM
evade's Avatar
No lurkers...
I understand compressor/tank/lines/fittings/controller/etc... I'm looking for specific info on the front shock assembly fitment and top mount/bearing.
Old Dec 4, 2012 | 07:58 PM
Pezee's Avatar
2005 c230 Kompressor
im running airrex
Old Dec 4, 2012 | 10:47 PM
C320-Cav's Avatar
C320
I got a bagged C320
Here is pics of the setup
Current compressor is kinda small, planning on getting a bigger one.
