Battery Question
Old Oct 28, 2012 | 07:40 PM
CLK Group's Avatar
2008 ML320CDI 4Matic, 2006 C350
Battery Question
My wife's 2006 C350 has been in storage for six months with the battery disconnected. The storage unit has no power so I was unable to keep a trickle charger on it.
When we return next month I'm going to assume the battery is flat.
I have researched the forum and found different answers for my question:
Can I jump start the vehicle or do I need to first have the battery recharged?
Thanks in advance!
Old Oct 28, 2012 | 08:22 PM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
My ML320 is usually in storage for 6 months out of each year. I also disconnect the battery before storing. I usually re-charge the battery, then start the truck. That's what I'd recommend you do the same.
Old Oct 28, 2012 | 08:26 PM
SunnyRayToronto's Avatar
2003 C230 Sports Coupe, Paprika Metallic Red, Auto, Pano, Leather
Follow instructions from owners manual on disconnecting-reconnecting (changing) battery,....
Recharge battery via trickle charger only. Mercedes-Benz OEM trickle chargers are by ctek
NEVER jump start a mercedes battery!
Old Oct 29, 2012 | 12:23 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Doesn't say much for German electrical engineering or that the car is a tourer.
You wont find a Mr. Battery in the bush!! Your only option if you have left the lights on will be to take a jump from a Toyota Landcruiser.
I think you can lessen the chances of damage to SAMs ect by jump starting by.
1. Having ignition off & key removed.
2. Lessen voltage shock by having donor car engine stopped ie 12 V vs 14 volts.
3. Connect jumping leads in the correct sequence & do so quickly & firmly to minimise sparking.
I understand the the later 203's are as not as sensitive to damage as the earlier ones.
