freshly bagged 07 c280 4-matic
2007 c280
Yeah I don't have the sway bar bolted in yet, I wanted to make sure everything was going to work before I welded the tab on for it and I have to notch out the bracket for the abs wire. The struts are the airlift universal high dampening struts and it comes with the bags and all the metal to make the brackets and strut mounts, I ordered mine from kevin at airassisted in Canada
2007 c280
#33
2007 c280
#36
Same one I have!
Wanna tell me how long does it take for your car to raise after being lowered all the way??
and how long it takes to lower?
Nice installation too! Very clean, i like it. Keep up the great work!
Does yours rub when you fully steer? Mine rubs like crazy even when lifted but as for going straight its fine. I wanna try and somehow bend the mudguards inside the fenders to avoid rubbing when i turn, it sounds terrible Do you have any advice? Your ride looks amazing btw
#37
2007 c280
It's actually fairly quick and I'm only using 1/4 line, I'm actually thinking about getting a regulator for the dump to slow it down a little bit. I've been talking to the guys at stancelab.com about making some camber plates which would be awesome and really nice for getting proper fitment on wheels. I'll keep posting pictures as i make more progress
#38
30 seconds each end. But i feel as if it is too slow. I'm gonna upgrade compressor and my gauge as well. Awesome work man! I'm really looking forward to seeing the progress
#39
2007 c280
I was looking at your thread and I'm kind of confused, are those the tanks on the right and your compressor and valves in the middle
#40
2007 c280
And how are you guys able to drive aired out in the front, even with my stock 16s when aired out my tires are tight against the inner fender well and I still have to go lower with my bags before there bottomed out
#43
As far as my ride I'm riding on 19's and when I'm full lowered i can go straight without rubbing the inner fender or turn about 15 degrees that's when it starts rubbing but when I'm fully raised the wheels rub when the i steer completely. I.e. taking a 90 degree turn will make the wheels rub inside. I'm looking to sell my haste's and get 18" BBS LM reps and hopefully that gets rid of all the rubbing
I suggest you get the wheels spaced a little or chamber kit to reduce the rubbing
How wide are your tires in the front??
#44
2007 c280
Im picking up a job at jiffy lube hopfully this week! Had a succefull interview and when i rack up enough money im headed over to 2zero6factory.com and picking up new compressor, tanks, and digital gauges.
#45
My set up, even when my car is completely lowered doesnt sit on top of the wheel
#46
#48
2007 c280
Well I went to leave work today at -10 degrees and my heater would not come on, checked all fuses and everything was good so I'm not sure what's going on. Probably won't be doing much to the car till this problem gets fixed,
And yes the top of my tire when I'm completely aired out is hitting the top of my inner fender
