Steering wheel adjustment problem..
Old Nov 24, 2012 | 07:52 AM
khaled.alameddi's Avatar
C240 2002 w203 with C32 body kit
So i bought a used w203 C240 2002, and the steering wheel adjustment is fully functional for presets but the actual button that controls the steering wheel does not function at all.
So i went to a mechanic and he tried replacing the door control module and another module that was in the door itself and even tried changing the module under the driver's seat but still the problem persist. Yet again the preset buttons DOES move the steering wheel back/forth and up/down ... Any help ?
Old Nov 24, 2012 | 09:11 AM
MBfinatic's Avatar
e36 318i, 2004 sti
My C55 had this problem. It is a little dog bone piece under the steering wheel. You will need to remove a lot to get to it. The part is a couple bucks. I will try to look it up.
Maybe this will help- https://mbworld.org/forums/c-class-w...d-working.html
Old Nov 24, 2012 | 09:14 AM
But if the little piece was broken, would the steering wheel still adjust its position normally when preset button is pressed ? (which is my case)
