Question For You Guys With Cut H&R Springs!
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
i have seen that a few of you guys have half a coil cut at the front!
how can the spring be fitted correctly with half a coil removed?
the top and bottom spring seats have a cut out for the spring to locate.
if you remove half a coil the spring wont sit properly?
i understand if you cut a full coil the spring will fit properly but this is way too low.
cheers
cheers
