How do I remove this panel? Drivers seat.
Old Dec 5, 2012 | 03:39 PM
Hogger's Avatar
2009 ML350, 2007 GL450, 1963 GMC, BMW 325i
I can't get the knob or the control buttons off without breaking something.
I've searched here, and been all through AlldataDIY without any luck.
I need to remove the panel so I can re-install a bolt that came loose that supports the front of the bottom cushion, on this side of the seat.
Old Dec 7, 2012 | 02:34 PM
Hogger's Avatar
In case anyone needs it.
Remove seat belt bolt cover, remove seat belt bolt. Carefully, but forcefully remove front seat rotating knob. I ended up breaking a couple of the tabs that help hold it in place. On the rear of the panel, where the back seat passengers' feet would be. There is a little plug that holds the rear of the panel on, just give it a little tug and it pops off. There is a little tab on the front of the panel, so you just slide it forward. Rotate rear of panel upwards, and undo power seat wires.
Now have fun getting the bolt to line up through three holes... It sucks!
Old Dec 7, 2012 | 03:09 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
It can't be too hard for the Bubba Watson of car repair!
Or any more difficult that doing the head.
Old Feb 22, 2021 | 01:11 PM
skins's Avatar
C180 Elegance 2001
I'm having real trouble getting that rotating knob off. It seems stuck fast. I need to remove the panel to replace the switch unit for the power seat. Does it really just pull straight off?
Old Feb 22, 2021 | 07:07 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
My understanding is yes. Except it's on there real tight. Personally I would be expecting to buy a new knob as well.
