C220 cdi engine management light
Old 12-11-2012, 04:45 PM
Bonesmakoy's Avatar
Mercedes c220 cdi 2004
Hi,the management light came on in my car,so I took it a good run at speed and the light went off and it's never came back on,any ideas??? Cheers
Old 12-11-2012, 05:30 PM
phister's Avatar
06 C230 SS 6spd
go to an auto store and see if you can pull the code. the code is still stored in the ECM even if its cleared. you might have to use a STAR diagnostic to read the code.
Old 12-12-2012, 01:56 PM
Bonesmakoy's Avatar
Thanks mate,I got it checked today and it said the dpf was blocked.something to do with a carbon build up? Sounds expensive
Old 05-06-2015, 09:41 AM
11dougd's Avatar
C220
Engine management light
Hi I have a C220 cdi 2005 and the engine management light is continuously on. Took it to the motor way it won't clear. It does not have DPF on it. What might be the problem. If you take off on speed it does not speed. It will pick up speed after sometimes
Quick Reply: C220 cdi engine management light
