Change batteries in Smartkey, now it wont work,,,,help!!
The Smartkey was acting out...sometimes it would work and some others it wasn`t...so I changed the batteries but now it wont work at all...I called the dealership,,,the want to see if the problem is either the batteries or the car..does this make any sense??? If key is the problem..I will need to buy new one for $270.00...not happy ....help please~!!!!!!
From what I read in the book, it may need reprogrammed by putting it in the ignition and switching it on.
Yes I did, I drove the car around the parkway...and nothing....I really started to wonder if it has something to do with the power locks.
2005 c230 kompressor 2003 s500 94 wrangler
did u clean the battery contacts with lint free cloth?
u could have damaged the contacts or wrong batteries?
do u have 2 keys anyway? if u dont might be that time for a spare
No I did not clean the contacts,,,but I did kind of open it to retrieve the old batteries out..That was kind of stupid thing to do on my part..but its nor broken or anything.....and I dont have a spare.
Omg..believe me I did so many times...I even put the old batteries back just in case I had bought the incorrect ones..but nothing...I should just leave them the way they were before...at least it was working somehow//god or bad.
Tommmmmmmmmmyyyyyy....thank you...you got me thinking twice again,,,,yes I was puttin the batteries on upside down and the other faceing it,,,,like a sandwich......yes, yes , yeeess....thank you so much
There are two systems in the key. One is a radio transmitter and requires a battery in the key to work. The receiver in the car "listens" for your key and opens the locks, locks the car, opens the trunk (not for wagons,) or fires off the panic siren. There is also an infrared circuit that runs on the battery. It will perform all of the above functions plus roll up the windows and close the sunroof (if equipped) if you hold the "lock" button while pointing the red window on the key at the photoelectric cell on the drivers door handle from a few inches away.
There is a wee LED on the key that will flash red if the battery is strong enough to operate the key. You can clean the battery and contacts with isopropyl alcohol if soiled. The red window in the key and your EIS (where you put the key) with Windex and a soft cloth.
You can take the battery out of the key and it will still start the car. You must use the metal key to open the door, but when you insert the key in the EIS a transformer primary induces a current in the key to use the Ir (infrared) system to start the car. Handy to get home if the battery dies.
The key is programmable, but it can be done only once. If your key was working, it has already been programmed, and it cannot be erased and done again. Don't buy a "spare key" from Ebay. They are worthless.
If the former goat herder that is now working as a valet at an overpriced eatery in Beverly Hills throws your key across the lot for the ex-camel jockey to hang in the little cupboard, it may jar loose the secondary coil in the key and break the wire causing the key not to work when insrted in the EIS. That is why you should not drop the key either.
There was a time when you had to attend a dealer with your "papers please" to get a new key. Legitimate locksmiths are now allowed to know the secrets of the Kingdom of Sindelfingen, and can supply keys.
2004 Civic Si. FWD for the Win!
Glad you got it to work out.
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
