Coilover problems
Old Jan 1, 2013 | 08:32 PM
CKlasse230's Avatar
C230 Kompressor
Lightbulb Coilover problems
Ok long story short I installed my coil overs today and my tire rubs a lot wit the preload perches. I add a 10mm spacer and it still rub like crazy?????? Wth can it be I need help really bad please help me
Old Jan 2, 2013 | 12:26 AM
glocati's Avatar
2016 GLE 350
What is the offset and width of your front wheels? Also what size tire up front ? Also, what coilovers. All of these factor into it.
It may be, that you need just a few more mm fatter spacer, or one size down width-wise on the tires.
Old Jan 2, 2013 | 03:09 AM
phister's Avatar
06 C230 SS 6spd
If you go too low on the fronts and don't have the wheels out far enough it's gonna rub the perch and spring. And even if you do add spacers your tires might need to be stretched. I had the same issue with running 225/40/18 and now I'm on 215/40/18 and no issues.
