Koni Damper set and springs
Old Jan 9, 2013 | 11:31 PM
wheelz's Avatar
AMG's
Has anyone used this on there coupe or sedan? Is there a better option out there. Don't want a bumpy drive and looking more to have the front the same height has the rear while keeping a comfortable ride.
http://www.tirerack.com/suspension/s...3&autoModClar=
Old Jan 9, 2013 | 11:33 PM
wheelz's Avatar
AMG's
Would this be better?
Old Jan 10, 2013 | 10:06 AM
phister's Avatar
06 C230 SS 6spd
H&R coilovers are going to a stiff ride. I would look for a set of SS springs and struts maybe or get some some koni yellows with springs. They have a 5 dampening adjustment to control ride comfort from hard to soft. or Get a set of BC coilovers. I have them and love them, its has 30 dampening adjustment and you can really dial in your ride comfort but they also do custom spring rates when you order them so you can a soft OEM spring rate or a stiffer spring rate. the standard spring rate for them if you dont do a custom is 8kg front and 6kg in the rear. its a nice ride and not to stiff.
Old Jan 10, 2013 | 09:43 PM
wheelz's Avatar
AMG's
Thanks. Getting the BC coilovers tomorrow. They were closed when I tried to call them.
