Why can't I rev past 4K in neutral?
Old Aug 5, 2003 | 02:31 PM
czachari's Avatar
2003 C230
The engine cuts off as it approaches 4k rpm. It works fine when in gear
CZ
Old Aug 5, 2003 | 03:15 PM
Lynn's Avatar
The rev limiter cuts in at 4000 rpm in neutral to protect the engine from accidental, or maybe intentional, overrevving. I think it also works on six speed cars when the clutch pedal is depressed.
Old Aug 6, 2003 | 12:20 AM
Outland's Avatar
2002 C230 Coupe(M111)
Revving an engine in free state, with no load on it can damage it far more quickly than revving past redline under accelleration.
That limiter is there for a reason. Frankly, unless youre just trying to kill the clutch, 4K should be plenty- you launch a car at its torque peak, or just past it, to get the strongest launch. I think the M111 hits max torque just past 3K, but from 2500 to 4800RPM the engine is over 200ft-lbs.
