Door light not working.
Are you able to lock the door with the remote and is the window functioning properly?
If so, then you're right, the fuses are good. If that is the case, you will have a tough time getting to the wires since there is some type of adhesive cover behind the door panel. Try connecting one of those little things that detect if something is producing electricity(i forgot what it is called) You can buy one at harbor fright tools or ace hardware for $5-10 bucks.
Good luck mate!
Hello would you be so kind and let me know wheres that fuse that you have changed/check i need to fix since my door lights wont work on the four doors, thank you so much.
