Problem with Key
Old Jan 27, 2013 | 08:02 PM
billyons's Avatar
2001 C320
Problem with Key
I have the standard black w203 keys. I have one and my wife the other, when we bought the car the keys worked equally. No difference between them.
Since I am the primary driver for this car, my key has seen more abuse than hers and has developed cracks on the Open and Lock buttons. Then one day when I unlocked the car, all 4 doors unlocked, instead of only the drivers door.
I contributed this to the cracked key because my wife's key works like it did from the dealer.
I bought a new MB key shell, transferred the electronics from one key to the other (installed fresh batteries in too) and the key works great, except for the key unlocks all the doors instead of the drivers door only.
I have tried numerous ideas to fix this and nothing works.
How can I stop all four doors unlocking when only the driver door should be unlocked?
Also at one time both keys were able open and close the windows and sunroof with the key. Neither key can do this function now. Any thoughts?
Old Jan 27, 2013 | 08:44 PM
samaritrey's Avatar
Super Moderator
THE C350
Well this is easy you enable the unlock of all doors with your key but not hers. Simple setting change you hold down the lock and unlock for like 10 seconds and it switches back and forth it is in the owner’s manual.
Second issue is the ir sensor in the door probably went out don't bother trying to fix to expensive.
Old Jan 28, 2013 | 12:17 AM
billyons's Avatar
2001 C320
Thanks, that did the trick. My manual is currently hiding from me.
Old Jan 28, 2013 | 09:58 PM
samaritrey's Avatar
Super Moderator
THE C350
You can get a pdf copy from Mercedes web site till it comes out of hiding
Old Jan 29, 2013 | 03:04 AM
phister's Avatar
06 C230 SS 6spd
You can download the manual in the wiki link at the very top
Old Jan 29, 2013 | 04:54 PM
KHARBAT1's Avatar
2002 MERCEDES BENZ C320
1- Selective set up : will open the driver door with the first CLICK , the 2nd CLICK will open all doors and trunk .
2- Global set up : One CLICK will open all doors and trunk .
So , you must have changed the selective to Global , you can change back to selective as was explained ubove.
Old Jan 29, 2013 | 05:22 PM
KHARBAT1's Avatar
I went to chk my car , put the 4 windows down , the back door behind the driver didnot come up, I tried many times, up and down , i hear the motor noise and a little movement with the glas , but it is below the level and i canot help it by hand . Any ideas ? Thanks
Old Jan 30, 2013 | 05:17 AM
phister's Avatar
06 C230 SS 6spd
Remove the door panel. The motor might be going out or it might be jammed
