12V power always on???
1988 560SL (Sold)
Before you trash me on this one, I have RTFF and STFF for the last 30 minutes.
Is it possible to have the 12V lighter/adapter wired as unswitched (i.e., always on)? I know what the dealer says, but that probably means that it IS possible!
Tim
Tim
C230Kompressor
I asked the exact same question on csportcoupe today! T'wud be so nice to have a hot plug in there. I assume someone has found a live wire in the tunnel?
Administrator
Re: 12V power always on???
Tim
Tim
You need to remember that you can play the Audio system for a while without the key being inserted for one. The other tap-in would be the power for the illuminated door sills as they are ground switched.
With these 2 examples in mind it shouldn't be too difficult to do some minor rewiring depending on how much power you plan on drawing.
Hope that helps and gives you more ideas where to look.
