Need to replace air intake c230k?
Old Mar 5, 2013 | 05:51 PM
funnyent's Avatar
c230k
Hi All -
I noticed that the air intake for the supercharger on my C230 Kompressor is split right behind the front grill of the car. The rubber tube is just somewhat unraveled right there. Will it hurt it if the supercharger is also sucking in some air from inside the hood? I'm going to have the dealer look at it during the next service, just wondered if it needed to be repaired soon.
Thanks!
Tim
Old Mar 5, 2013 | 06:14 PM
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
haha just had this happend to me like awhile ago
damn thing is crap...but as soon as i put the new intake the car warmed up faster, sounded better, and ran better
its not big deal to wait but it will save gas
phister's Avatar
06 C230 SS 6spd
it will be ok. its just an air hose till it gets to the air filter. you can just buy a replacement part from rmeuropean or mymercedesparts or even look in the classifieds. Many guys with the kompressor replace the hose with a silicone or rubber hose to have a more smooth flowing air flow to the filter.
Old Mar 7, 2013 | 12:11 AM
funnyent's Avatar
c230k
Ok, Thanks for your help! I ordered the part online and will just replace it myself.
Old Mar 7, 2013 | 10:08 AM
by the rad support theirs 1 clip on top and 1 clip on bottom.. use a flat head screw driver to press down on the tab then u can just take out the bottom by sliding it foward or back
make sure u put the bottom clip on first or it will be a ***** to do
Old Jan 11, 2014 | 12:44 PM
slimpee's Avatar
2004 CLK 55 Cabriolet
I'm bumping because my cloth hose is torn and i'm wondering if it could be the cause of my CEL and/or sorta rough idle. I can't really imagine why it would kick a code but maybe if the engine isn't getting the airflow it needs, it would. I read the post about the clips; is there anything else I need to know about replacing the hose?
Thoughts?
Old Jan 11, 2014 | 01:01 PM
funnyent's Avatar
c230k
Thoughts?
I doubt that would be the case. I ran mine for almost a year with a broken one until I replaced it last spring. It's still getting air, just some of it would be from inside the engine compartment instead of pulling from the grill. Go get your code pulled from Autozone (they do it for free) to make sure though.
Old Jan 11, 2014 | 01:35 PM
slimpee's Avatar
Yeah, that's sorta what I thought, too. I have the part so i'll throw it in and then run the code. I may also pick up some MAF cleaner and try to sort through the forum for a good guide on doing that.
Thanks!
Old Jan 11, 2014 | 05:00 PM
slimpee's Avatar
So I replaced my air hose w/ an MB unit and wow...it made a difference! The car is definitely idling smoother (although it wasn't super rough to begin with). I'm glad I did it!
It didn't seem to have anything to do w/ the code, which was related to the thermostat/coolant temp, but i'm still pleased with the result.
Old Jan 11, 2014 | 08:41 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
How badly was it split?
Mine is also split - looks 'kinda' ok at first glance, but it definitely sucks some air from inside the engine compartment.
Old Jan 12, 2014 | 03:59 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Mine split a few years ago. I just used Krazy Glue and popped it back together?
Considering it's just a hose connecting the intake to the outside, I can't see how this thing would affect the performance of the car at all? Looks like the bends in the tube are more for keeping water out, and even then there's another plenum where the engine air filter is located.. That's why I never bothered replacing mine..
Old Jan 12, 2014 | 09:19 AM
slimpee's Avatar
Mine was coming unraveled at both ends. I duct-taped it but it didn't stick well to the fabric. The new unit was $50 from the dealer so it's a relatively inexpensive fix.
I'm not sure why a torn hose would have a deleterious effect on operation...perhaps the engine isn't getting enough volume or the flow is too turbulent or something. All I know is that for at least a day, my car idled smoother than it has ever before.
Old Apr 13, 2014 | 09:06 AM
2subway's Avatar
C230 2003
part number ?
Does anybody have a part number for this air hose you all speak of? Mine is in very bad condition and I would like to replace it. I would try to search but I don't even know what it's called
THANKS!
Old Apr 13, 2014 | 01:29 PM
VVF's Avatar
VVF
http://www.parts.com/parts/2003/Merc...iagram=5775022 That's how it called. The part number you can get at mbpartsworld com
Old Apr 13, 2014 | 04:04 PM
2subway's Avatar
C230 2003
Got it! Thanks!
Old Mar 1, 2020 | 10:39 AM
bamacowboy1's Avatar
03 MB c230 Kompressor sport coupe
Replace the tubing
I had my thermostat housing replaced on my 03 c230k and the o-ring didn’t seal properly so the tubing got wet and split apart. Looking at it I realized that there is no reason to pay $50+ dollars to replace the whole intake tube when 3” intake tubing is very cheap and is easily attached to the hard plastic end pieces.
Old Mar 1, 2020 | 01:55 PM
Red Fox's Avatar
C230 Kompressor
You can get a plastic airduct hose from Auto Zone for about $20. Made by Spectre, part number 8741. See YouTube
Old Mar 1, 2020 | 05:59 PM
5by5's Avatar
2011 C300 Sport 4matic, 2005 C240 4matic, 2003 C230K Sport, 1999 C230K Sport, 1969 220D (first car!)
I repaired mine for a while by putting a open ended tin can or pop can (just find something that fits snugly) inside the ripped area as a coupler and applying two hose clamps.
A few weeks later I had an OEM replacement. No real difference between the two in how the car ran but I felt better with the new one. About $50 for the OEM version from an online retailer. Knock-offs on Amazon were about $30.
5
