cold engine
Old Aug 18, 2003 | 07:48 PM
c230_kS's Avatar
cold engine
do u guys get the problem on ur c230k sedan or coupe? like the gear holds and let it go all of a sudden and car sort of slide out quicker when the engine is cold in the morning?
Old Aug 18, 2003 | 07:51 PM
Matt230K's Avatar
2010 C300 4matic
It's not a problem. It will hold the gears longer to keep the revs up and warm up the engine quicker.
Old Aug 19, 2003 | 03:45 PM
moomeh
Guest
Posts: n/a
yet another reason to love summer.
Old Aug 19, 2003 | 03:55 PM
BrabusCClass's Avatar
GL450, Sienna SE
I warm up my car so i never noticed this problem.
Old Aug 19, 2003 | 04:25 PM
c230_kS's Avatar
this kind of problem is not really obvious on bigger engine cars? like i dun feel them when i drive an 330ci.... is it becuase of the supercharger and so make the car rougher in general?
Old Aug 19, 2003 | 07:04 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Now you are comparing an I4 with an I6. What Matt says holds true for most cars.
Old Aug 19, 2003 | 07:18 PM
c230_kS's Avatar
hm ok....i mean the roughness.....is it rougher? when I4 cold engine switching gears.
Old Aug 19, 2003 | 07:39 PM
Matt230K's Avatar
2010 C300 4matic
It probably has less to do with the engine configuration and more to do with the transmission and the way it is programmed. Regardless, it's normal, so you either have to deal with it or get a different car.
Old Aug 19, 2003 | 09:59 PM
c230_kS's Avatar
does anyone know people that can reset the transmission and ECU not from the dealer or how to ask them to reset the transmission from the dealer
Old Aug 20, 2003 | 06:23 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Resetting the tranny has been covered. STFF because I'm too lazy.
