Problem in my 2003 C230 Kompressor
Old Mar 21, 2013 | 11:07 AM
ababiso's Avatar
2003 C230K
Exclamation Problem in my 2003 C230 Kompressor
Hi
I need your advice of what could be the cause and what I should do
The problem is that sometimes I realize poor acceleration and many times it seems like the car is stuck on one gear for more than 3 seconds (while pressing the pedal), then it seems that it changes 2 gear at a time,
and also when slowing down.
I took it to the Mercedes Dealer, said nothing wrong
later on I took it to a good mercedes mechanic -- nothing
another one and nothing
I bought a OBD2 scanner and found these errors:
P0120 - Powertrain: Throttle/ pedal position sensor/ switch a current
P2009 - Powertrain: Intake manf runner control circuit low bank1 a)
P201C - Powertrain
P2004 - Powertrain: Intake manf runner control stuck open bank1 a)
Thank you for your help
My Car is 2003 C230 Kompressor 186k
Old Mar 23, 2013 | 06:23 AM
ababiso's Avatar
2003 C230K
UPDATE
Update: I erased the fault codes then drove for about 10 miles
rescanned ---> no faults
symptoms are still felt
I made some scans that I will upload:
1- test on idle:
2- test on track 5% slope upwards:
3- test on same slope but downwards:
Attached Thumbnails Problem in my 2003 C230 Kompressor-idle.jpg   Problem in my 2003 C230 Kompressor-test.jpg   Problem in my 2003 C230 Kompressor-race-track.jpg   Problem in my 2003 C230 Kompressor-hp.jpg
Old Mar 31, 2013 | 08:10 PM
ababiso's Avatar
2003 C230K
plz write anything you think is helpful
Old Apr 6, 2013 | 08:51 PM
ababiso's Avatar
2003 C230K
non replies??
can it be a faulty accelerator sensor / pedal??
Old Apr 7, 2013 | 04:27 AM
phister's Avatar
06 C230 SS 6spd
It could be the TPS. Have you tried the throttle reset?
Old Apr 8, 2013 | 08:46 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
From the readouts it looks like a couple things.
The TPS threw a code at some point, but it sounds like the
tranny is the thing giving you pause.
Have you ever done a complete fluid flush?
Assuming you have an AT yes?
Perhaps time to do some tranny maint, and check to make sure there's no oil in the TCU
under the passenger footrest.
Old Apr 10, 2013 | 07:49 PM
Billymowat's Avatar
2003 c230 coupe
this is not really helpful to your post but i to have a 2003 c230 kompressor and it has a really bad vibrations and engine sound i thought it was the motor mounts but after i changed one of them i found out it was not any help would be greatly appreciated
Old Apr 17, 2013 | 06:23 PM
ababiso's Avatar
2003 C230K
[QUOTE=phister;5604995]It could be the TPS. Have you tried the throttle reset?[/QUOTE
yes I tried it several times
it works good only for few miles then again
Old Apr 17, 2013 | 06:32 PM
ababiso's Avatar
2003 C230K
yes my car is AT and I have already done a complete transmission fluid flush before but it did not help
and also I checked the TCU, its clean as new, no oil
