harmonic balancer tool
C-230. ZDMAK tools offers a tool they call a counter holder, that holds the harmonic balancer stationary to loosen the crank nut. The description of the tool does not list my vechicle. Anyone have experience with this type of tool to remove the balancer. I have also seen the tools which lock the flywheel in place but the counter holder seems to be much easier for this repair, just not sure if the ZDMAK tool will work on my balancer. Any information would be greatly appreciated
IIRC, the ZDMAK and all the others you can find online are just copies of the MB tool, just without replaceable pins.
You're probably aware of this, but just in case...don't forget that the crank bolt is torque-to-yield and SHOULD NOT be reused.
I can try to look up the MB tool part # on StarTek later if you'd like.
